Pair Garmin watch w...
[Closed] Pair Garmin watch with Lezyne GPS. Possible?
[#11198244]
I'd like to record heart rate, cadence speed, and route in a single file.
I've got a Garmin watch (takes care of heart rate, and route.
I've got a Lexyne GPS unit on the bars (takes care of cadence via feed from a little wahoo thing on my shoe, and route again)
Can I link these together somehow, or is there a smartphone app that I can use to achieve what I want?
Posted : 18/05/2020 5:22 pm
Presumably the watch uses an optical sensor? This article suggests maybe you can:
https://www.dcrainmaker.com/2020/01/garmin-adds-bluetooth-heart-rate-running-data-broadcasting-for-fr245-fr945.html
Posted : 18/05/2020 5:34 pm
Depends on the Garmin and the Lezyne I think. You could set your Garmin to transmit heart rate over ANT+, and pick this up using the Lezyne GPS. Compatibility matrix here:
ANT+ list
I use this setup with my Garmin Fenix 6 on my wrist, transmitting heart rate to the Garmin Edge on my bars. It's via ANT+, so not Garmin specific
Posted : 18/05/2020 5:35 pm
ah OK, thank you. I'll have a bit more of a play. Furloughed, so I have time to burn. Just because it's not obvious doesn't mean it's not possible eh?
Posted : 18/05/2020 5:40 pm
As above , ANT+ broadcast heart rate on the Garmin
The lezyne should pair with the watch , mine does
Strava is one way of pulling all the data together in one place , just link the accounts in the lezyne gps ally app.
Posted : 18/05/2020 7:30 pm
Is the little wahoo thing ant+? If so, connect it to watch and you don't need the Lezyne as watch does it all.
Posted : 18/05/2020 11:29 pm
Just paired my Garmin Instinct with my Lezyne so that I can get the HR from the Garmin.
Fairly straightforward to do.
https://www8.garmin.com/manuals/webhelp/instinct/EN-US/GUID-D8D363C2-0690-48D4-95E2-A3557E7D53C2.html
Posted : 19/05/2020 1:10 pm
thanks for the tips! The lezyne wouldn't pair with the Garmin (lexyne is more basic model, so Bluetooth only, no ANT+)
However, the wahoo cadence sensor has paired with the Garmin watch, so mission accomplished, without buying any other gadgets. 😊
Posted : 20/05/2020 11:20 am
