Painting carbon bit...
[Closed] Painting carbon bits
[#8388699]
So I've some carbon bars on my son's frame that are not very co-ordinated. If I wanted to paint them jet black I presume it's as simple as:
1) rub down with fine sandpaper
2) spray carefully with some car spray paint from Halfords like http://www.halfords.com/motoring/paints-body-repair/car-spray-paints/halfords-matt-black-spray-300ml.
Right?
Posted : 07/03/2017 9:29 pm
Why not just rub the paint-off with fine wet/dry and leave them natural carbon? Painting them will just make them look, err rubbish if not done well.
Posted : 07/03/2017 9:38 pm
Naked Carbon fibre and water don't mix that well, I'd want some kind of lacquer /clear coat on them.
I'm sure it's not a massive issue unless for prolonged periods but personally I'd either spray them matt black with a suitable paint or sand the coating off and recoat them with a clear coat to insure they are reasonably sealed from moisture.
Personally I think I'd sand them very gently so the new paint can take, and then just spray them matt black.
Posted : 07/03/2017 10:18 pm
With a spray can, little and often is the key, leaving a good 20 mins drying time between coats, which should literally be a dusting, lest you end up with a lumpy finish and paint runs.
Posted : 07/03/2017 10:26 pm
