Pain Cave Flooring
[Closed] Pain Cave Flooring
[#9667775]
Turbo is setup in the garage which has standard concrete floor. I want some form of rubber matt to go under turbo.
Has anyone used those rubber tiles? Do they work well in this situation. Did you use the ones with patterns on or plain? Any cheaper alternatives?
Posted : 15/11/2017 11:00 am
Get the £10 interlocking ones from Halfords. Use two layers if you want a bit more give.
Posted : 15/11/2017 11:04 am
I've done my garage floor with [url= http://www.bigdug.co.uk/mats-flooring-c402/interlocking-floor-tiles-c1789/value-interlocking-vinyl-floor-tiles-p14434 ]these from Big Dug[/url]. 14mm thick and they're excellent.
You can buy edging so can make a nicely finished area to sit the turbo on.
Posted : 15/11/2017 11:08 am
SO they stay together ok then? And don't lift at the joins?
Posted : 15/11/2017 11:10 am
keeping them together is fine, it's the sweat though, i use a gym mate which is like a full on plastic coating and doesn't absorb the sweat, just pools it and then i mop it up with rags etc.
Posted : 15/11/2017 11:13 am
For those using rubber tiles: paint the floor before laying them? Or just put them straight down onto the concrete?
Posted : 15/11/2017 11:17 am
off cut of cheap vinyl flooring, wipe clean! you could always but it over the matting or some carpet underlay
Surely that's better than anything absorbent? It would get pretty stinky after a few weeks I would of thought.
Posted : 15/11/2017 11:24 am
The ones I've linked to don't lift at all, they're solid - I have a car parked on mine. My floor was painted previously but there's no need to.
I use a rubber stable floor mat. Only con is that it's bloody heavy to move!
Posted : 15/11/2017 12:07 pm
I currently use a cheap yoga matt, I stole mine of my wife but they're about £5 new from places like TK Maxx.
Posted : 15/11/2017 12:12 pm
found this.....
1m x 3m works out to £16
https://www.polymax.co.uk/rubber-matting-and-flooring/rubber-matting-rolls/fine-ribbed-rubber-matting-fina
Posted : 15/11/2017 12:21 pm
How do you cut them to size? Stanley knife?
Posted : 15/11/2017 12:24 pm
Possible I guess but I used an angle grinder. I don't get a chance to use it much and it's so much fun to use 🙂
Posted : 15/11/2017 1:04 pm
My turbo lives in the garage. It's on a piece of old carpet. Does the job fine.
Sweaty, stinky smell? The garage is full of funny smells so one more is not noticed.
Posted : 15/11/2017 1:36 pm
Yes, that's why i use it 🙂
Posted : 15/11/2017 1:38 pm
Why do you need any form of mat, just curious?
You are using a fan?
Posted : 15/11/2017 1:39 pm
FunkyDunc - Member
In a Zwift race i'll drop almost 2kg of sweat in an hour long race. There's a massive puddle of sweat beneath the bike along with my clothing which goes from lightweight to heavy ! Plus the sweat towel....
Posted : 15/11/2017 1:42 pm
Yes I am using a fan. Not sure why you ask.
As for the matt, its to protect the feet of the turbo and the front wheel block and stop them moving around on the concrete. It may reduce vibrations/noise also but that's a bonus as its just me in there and the noise doesn't travel to the rest of the house anyway
Posted : 15/11/2017 1:55 pm
Even with a fan on full blast in the middle of winter there will be a puddle of sweat that needs mopping up afterwards.
I use the Halfords foam mats. 3 are all I need to cover the area under the turbo.
Posted : 15/11/2017 2:01 pm
Sounds awful.
Posted : 15/11/2017 4:14 pm
Come to think of it, I have a jigsaw and a blade for laminate floors, so that would probably work. Do you need to leave an expansion gap or can it go right up to the wall?
Posted : 15/11/2017 4:24 pm
I used the edging strips and went right to the wall. Fortunately my garage was the exact width of x number of tiles plus an edging strip each side.
Edging strips aren't really needed but it was either that or buy more tiles and trim them down to fit the gap.
My garage was painted concrete before and these have made a massive difference to comfort and warmth. Plus it looks amazing 🙂
Posted : 15/11/2017 4:53 pm
lunge -
I currently use a cheap yoga matt, I stole mine of my wife.
Same here (but from my girlfriend as your wife couldn't find hers... ).
I'm upgrading to a new mat after Christmas as surely there'll be yet another unused yoga mat going free 🙄
Posted : 15/11/2017 4:57 pm
