My X-Fusion Vengeance HLR seem to have lost 15mm of travel.
Out of the box, there was 170mm of stanchion showing, now there is 155mm.
I've tried pulling them, bouncing them, letting the air out, pumping them up to max - no change.
Interestingly, the DLA still drops them by the usual 30mm, so when switched over, they now sit at 125mm, rather than 140mm.
Rebound and high/low speed compression all seem to be working fine.
I'm guessing it's a problem with the negative spring and they are undoubtedly going to have to go back - just wondered if it's a common known problem.
Negative spring issue, I'd guess either air transfer or neg spring, return for a warranty inspection as may need parts.
Cheers - as I suspected
Excellent service so far from Freeborne - emailed them 15 minutes ago and a nice chap just called me to discuss.
Going back tomorrow to be checked!
