Pace RC36 oil chang...
[Closed] Pace RC36 oil change - what oil? How much?
[#376658]
I'll keep it simple this time.. does anyone have a vague idea of:
1) How many cc's of oil to refill a pair of Pace RC36 (pro-class II's) - or similar forks?
2) Which weight oil should I put in?
3) Presumably motorbike fork oil will do the job, won't it?
My earlier, more detailed and unanswered ramblings on this problem may be viewed here: [url] http://www.singletrackworld.com/forum/topic/changing-fork-oil-on-pace-pro-class-iis-how-what-oil#post-190274 [/url]
Please, help, advice. Please. Thanks!
Posted : 10/03/2009 9:13 am
Here we go 2 3 4
I will try and find the manual for you today , if so I can scan you a copy
motor bike oil is brilliant cos it is cheap unlike cycle oil and the same stuff
Here is a drawing of the forks with a parts breakdown which may be of help
Posted : 10/03/2009 9:20 am
I use 10wt fully synthetic motorcycle fork oil when servicing. Never had a problem and as saladdoger said, it's much cheaper for a lot more.
Might be worth getting a small syringe as i have to inject my oil through the bolt hole that attaches the lowers to the stantions.
It's quite easy, just take yor time.
Posted : 10/03/2009 9:35 am
cheers saladdoger! That's exactly the sort of information I was looking for!
I had a feeling I'd seen something like that about on t' net somewhere, sometime.. I shall disassemble my forks with a little more confidence now!
Posted : 10/03/2009 10:53 am
...If you do get a chance to scan the manual that'd be most appreciated too!
email: alan.jones@imperial.ac.uk
Posted : 10/03/2009 11:09 am
I have found the manual, I will try and send it to you tonight
Posted : 10/03/2009 11:44 am
