I'd like to mount a mudguard onto the seatstays of a turner flux, but the stays are square extrusions
I've got a mudguard from decathlon that mounts using the v-brake studs
[img]
[/img]
I was thinking of trying to mount a decathlon mudgard using a pclip
like this from evans
[img]
[/img]
or something more generic
[img] http://t0.gstatic.com/images?q=tbn:ANd9GcRm7M3S6HHU5Jbf7QBTCmePyq08wBr8W71_dqa9wtwVUfWTfsC3j7r4A1nMvQ [/img]
any ideas whether these p-clips are flexible enough to work with such a square shape asa the flux seat stays? Any other ideas?
P-clips are pretty deformable - try pre-bending with pliers to a square shape first.
Am pondering the same thing with the 5spot so i dont cover the little un with mud when on the trailgater.
I have some nylon adjustable P clips in I think three sizes, they may be more flexible. Drop me an email with your address and I'll post you some.
Try the zefal no- mud. No p-clips required..
It has thick zip-tie style fastenings. Looks similar to the decathlon offering but sits better on the square stays I reckon.
I have the same Decathlon guard & similar square stays.
Used p-clips on my old frame, was ok but not brilliant
Not got round to experimenting with this one yet
Jules, that's exactly what I'm planning for the 6 pack. I'm pretty certain that with a pair of slip joint pliers, I can make those p-clips as square as they need to be.
I put a strip of inner tube round the frame so the clips didn't have to be fully square
I'm sure it'd be just as easy with cable ties
I've used the plastic mounts that come with reflectors in the past a bit more deformable. Or you could pad out the frame with a small amount of rubber (innertube) to make it rounder.
There might be other mounting options so pop into a hardware shop to see what they have.
Drill the frame...plenty of metal so you are not going to have a premature failure.
4mm Allen bolts should do it.
PaulD
Crud guard.
[quote=cynic-al ]Crud guard.
don't want it mounted on the post, want it mounted on the seat stays. got a crud guard, don't think it's efffective enough with the suspension
thanks for your useful input though
