Looking at a new set of risers & notice that nearly all are oversized so will have to buy a stem too. What are the advantages then and does anyone seek out and prefer the old 25.4 ones?
I wanted some wider bars for my Inbred - the stem is a 'standard' size and it did limit choice a bit, but there's still plenty out there. I didn't want to fork out for a new stem as well, seeing as the RF Deus is still perfectly good.
Ended up getting a Sunline V3 bar for <£30.
I think unless you are really hammering it, you'll not gain much benefit from oversize over standard - reckon it's more of a fashion thing.
some argue a std. is actually better/stronger
probably worth making the switch now as std stems are not as numerous and it will only get worse.
I was after some 25.4 bars for my Soul - can't bear to put fat bars on a skinny steel bike!
Got some Easton Carbons from Jenson USA, they were ridiculously cheap [i]because[/i] they're the less sort-after diameter.
I can't tell any difference in performance between either - I have a mixture between several bikes...
Definitely stiffer IME.
[url= http://farm6.static.flickr.com/5096/5390450588_377262c7dd_s.jp g" target="_blank">http://farm6.static.flickr.com/5096/5390450588_377262c7dd_s.jp g"/> [/img][/url]
Oops, misread title.
There are some bargains around in 25.4mm, ([url= http://www.chainreactioncycles.com/Models.aspx?ModelID=7155 ]50% off RRP 2010 flat EC70s for example[/url].)
I think a major advantage in oversize is choice. It's very tricky to find exactly the stem rise and length you're after in 25.4mm, unless it is a generic size. You can get just about anything in 31.8mm.
I didn't notice that much of a stiffness increase in size, but I really noticed a difference going from a noodly Giant stem to a chunkier RaceFace stem, on a old Giant AC a few years ago.
