Oven Broken Oddly
[Closed] Oven Broken Oddly
[#6480014]
Electric Franken,plugs into wall and is easy to pull out.
Switches on fine,fan comes on, clock works - but no heat coming out. Grill works fine.
Changed fuse, not that it should be that, no change.
Element in the fan oven gone maybe?
Is there another fuse I can self check other than the plug?
Posted : 13/09/2014 9:49 am
Yep more than likely the element,
Take it out and see if its split
Posted : 13/09/2014 10:05 am
Just changed the grills element in ours, still didn't work.. turned out it was actually the switch, the contact had melted (moved out of position) due to the current going through it (new switch look more heavy duty). Very annoying but it wasn't a hard to replace them, so don't right it off without taking a look at repairing it.
Posted : 13/09/2014 10:06 am
Thread title looks like one of those randomly generated passwords from the dictionary.
Posted : 13/09/2014 10:10 am
I had the same problem once. Turned out a thermal fuse at the back of the oven (outside) had gone,fitted new one and it worked fine again.
Posted : 13/09/2014 10:15 am
Right, I'll have a look at that when I get back from a ride.
Wasted enough time with this so far!
Posted : 13/09/2014 10:51 am
 nuke
I've had this twice the same as you describe on our Belling in-built oven (clock, fan and grill still working) and both times it was the element...just bought replacements off ebay
Posted : 13/09/2014 11:44 am
 Yak
Most likely to be the element.
Get one from ransomspares or similar shop.
I got one from there for mine. V cheap and about a 5 min job to replace.
Posted : 13/09/2014 1:20 pm
*hijack*Really enjoying saying Oven broken Oddly.
Lovely.
Like cellar door.
Posted : 13/09/2014 1:25 pm
Def sounds like element.
I've done a few on our SMEG found that the real part seems to last longer than the copies though.
Posted : 13/09/2014 1:37 pm
 J273
My Neff oven as done exactly this today. Fan comes on but the oven never gets hot with the temp control light staying lit.
Im thinking its the element and will fit it myself. I was going to pay £60 for the part but after ebay being mentioned above i've just checked and can get one for £7 🙂 Are these non genuine parts safe to use?
Thanks
Posted : 13/09/2014 1:44 pm
 nuke
I've noticed they do tend to get hot. hth
Posted : 13/09/2014 2:46 pm
Looks like it is probably the element. Checked and cleaned all the contacts - no change.
Rented house so I think I'll give the letting agency a call.
Also, note that cooking bread with a grill assisted fan oven is possible - albeit tedious.
Posted : 15/09/2014 10:00 am
