Does anyone make such a thing, or is this chainring-on-a-stick wishful thinking?
It seems only alu ones exist??
EDIT: Actually, it doesn't have to be NW as it's for single-speed mincing
I've seen steel round ones I think (SRAM) but not oval
Well it isn't exactly direct mount but maybe there is a 'new' standard for you
[url= http://singletrackworld.com/wp-content/uploads/2016/07/wolf-tooth-announce-new-chainring-standard/ ]http://singletrackworld.com/wp-content/uploads/2016/07/wolf-tooth-announce-new-chainring-standard/[/url]
So there are different kinds of direct mount by manufacturer? :/
Happens it is SRAM. 34T ideal - just fancy trying an oval one, maybe I'll have to go for ali - it probly won't explode.
edit: Stainless steel NW but not oval, soz
http://www.wolftoothcomponents.com/collections/stainless-steel
Well it isn't exactly direct mount but maybe there is a 'new' standard for youhttp://singletrackworld.com/wp-content/uploads/2016/07/wolf-tooth-announce-new-chainring-standard/
Oh Jesus! I just put together a NOS frame from 2010 - I can't cope with anything more recent than that 😆
But it may be just what you want if they do an oval stainless to go on a SRAM direct mount carrier.....
Think you're right there RB. I like the spiderless for a touch of weight saving, but seeing as I'm after steel over aluminum that might be a bit redundant.
Cheers for the info guys.
I couldn't find one, went for an AbsoluteBlack instead.
Almost made one though - manage to bend a round alu N/W when a bolt popped and I didn't notice, so replaced that with a Surly stainless (round one). Lost another bolt, didn't notice for a couple of rides but when I did, I couldn't put the bolt back in, as the ring had deformed and the hole didn't line up any more. Realised the ring was turning itself into an oval, so bashed it back into shape and ordered an oval one. Fitted it and raced the British XC the other week, I'd love to say it felt amazing, just felt normal.
Round ones were 34T, the oval's 36. I'm SS as well, I figure N/W isn't a big deal. If the chain's coming off then more likely the tension's not right.
So there are different kinds of direct mount by manufacturer? :/Happens it is SRAM. 34T ideal - just fancy trying an oval one, maybe I'll have to go for ali - it probly won't explode.
Did the OP never try Biopace the first time round? Didn't work then either! 😆
I'm younger than I look 🙂
