Oval Chainring. 104...
[Closed] Oval Chainring. 104mm/36T/Silver anywhere?
[#7861540]
Ive tried the usual suspects that I can recall, like SSC and Absolute, but cant find a 36T in Silver.
The only one I can find is on eBay from China, but I think the oval orientation is wrong, am I right? Tazzy?
The Chinese one seems to be orientated 0/180deg, as opposed to, say Absolutes and Tazzy's One-Key which IIRC is more -45/135deg?
http://www.ebay.com/itm/DECKAS-Bike-Single-Narrow-Wide-Oval-Chainring-Chain-Ring-BCD-104mm-32-34-36-38T-/272097673604
Absolute:
Posted : 01/06/2016 10:07 am
Anyone?
Posted : 02/06/2016 3:30 pm
That blue ones looks the same orientation as the AB no?
I was going to say that Mad Elk have good stocks of AB, but AB don't do a silver full stop.
Posted : 02/06/2016 3:53 pm
They're ^ not silver either 🙄
Posted : 02/06/2016 3:54 pm
Here's you're ebay one overlayed over the AB one.
I tried to line up the holes.
Maybe the AB is 96bcd, so it doesn't quite line up, but I reckon the clocking is very close.
Posted : 02/06/2016 4:01 pm
Cheers Alex. My wonky eyes must have got it wrong. Silver is an option at the ebay listing.
Posted : 02/06/2016 5:14 pm
Black one and oven cleaner?
Posted : 02/06/2016 7:38 pm
having placed the order, I've just realised the question of clocking in my case is moot!
The ring is going on a Middleburn spider which gives me loads of clocking options! Phew! 😀
Posted : 03/06/2016 5:16 pm
chain ring arrived today - 8 days from order from China.
Couple of interesting things to note.
1) the inside of the bolt tabs is a shade too thick for the recess on my middleburn spider arms. They'll need filing/grinding back to fit. BCD is correct
[img] https://goo.gl/dGMMc4 [/img]
2) there is a very slight clocking, by my reckoning and scribbling/playing with Jr's compass, it's about 10 degrees. I have no idea if that is sufficient. Tazzy, whats on the OneKey? But if I want more, I can rotate the spider on the arm as mentioned above.
[img] https://goo.gl/J7uYRE [/img]
[img] https://goo.gl/VgzJf1 [/img]
Posted : 10/06/2016 5:10 pm
Shame about the filing needed. They've probably tested on Shimano-only.
I reckon your 10-degree line is 5-degrees exaggerated though 😉
Posted : 10/06/2016 5:22 pm
well on a 36T, 1 tooth would be 10 degrees, so it probably can't be less than that 🙂
Posted : 10/06/2016 5:25 pm
Why - do the teeth have to line up with anything?
Posted : 10/06/2016 6:06 pm
I thought just that as I typed my previous post, d'oh! 🙂
Posted : 11/06/2016 5:58 pm
Still not silver but a reputable company - http://www.wolftoothcomponents.com/collections/elliptical/products/elliptical-104-bcd-chainrings. I use their stainless ring and they're beautifully made.
Posted : 11/06/2016 6:18 pm
