I have a road bike, with a Tubus Fly rear rack. I know I can fit Front Rollers (on the back), without heel strike, but clearance is 2 inches at most. Will I be able to fit Back Rollers OK?
I know they're bigger, but they taper to about the same width as the front rollers at the bottom, and they look like they have a longer top rail, so I should be able to mount them further back?
Can anyone with the back rollers let me know the dimensions (horizontal & vertical), between the end of the upper rail and the bottom corner of the bag so I can compare it to my front rollers?
I know I can adjust the brackets, but my front rollers are as far back as they will go. I'm trying to work out whether I can get the back rollers as far backwards.
Why not wask the retailer in question?
Cos he'll get a quicker reply on here?
31cm from top edge of top rail to bottom edge of bottom corner, top rail is also 31cm long 😀
Thank you! So it'll be a bit lower, but I can probably get it far enough backwards with the longer rail.
FWIW, I have a Fly on the back of my bike, and a pair of Back Rollers doing daily duty hung off it, no clearance issues at all for me using 170mm cranks and size 9.5 shoes, loads of room
There is a lot of adjustment in the clamps, you can set them up with the pannier practially hanging half off the back of a rack if you wanted to so I can't see how you'd have clearance issues unless you've got really huge feet and a really short back end.
Well, it's a 405mm chainstay, 175mm cranks and size 11 feet, so it's not ideal. Looks like it's worth at least ordering a pair to try though. Thanks for the help!
