Ordering Brakes fro...
[Closed] Ordering Brakes from Germany
[#4505449]
So if I order some XTR brakes from bike-discount.de will they come with the levers the right way round or will I need to remove them, swap 'em round and (obviously) bleed?
Posted : 29/10/2012 9:14 am
probably wrong way round but you can often get away without a bleed. You're likely to need to shorten hoses a bit in any event?
Posted : 29/10/2012 9:17 am
Got my Slx brakes from Rose, got the hoses swapped and shortened at the weekend. No bleed required.. Simples.
Posted : 29/10/2012 9:23 am
They'll come rear brake right.... I received a pair of saints not so long ago.
You'll need to trim hoses anyway, can be done no bother without a bleed!
Posted : 29/10/2012 9:37 am
Why not just bleed them anyway whilst you're doing it?
It doesn't make much sense to me to not do it, it's simple enough
Posted : 29/10/2012 9:43 am
Ok. Cheers. A bleed won't be a problem. I'm swapping from Magura so have plenty of LHM fluid knocking about.
I was just wondering.... In the past I've not had to shorten a rear as the hose was about right (though I've not had the tape measure out yet for this setup).
Posted : 29/10/2012 9:49 am
