Orange Five Sizing
[Closed] Orange Five Sizing
[#5617873]
Have got a potentially good deal on a second hand Five. Would mean a 2 hour drive to view it so don't want to waste my time if the sizing is wrong.
I'm 5'10 - what size Five are other guys the similar size riding and how do you find it?
Andy
Posted : 19/10/2013 8:55 pm
Would say a medium would be pretty much spot on.
Im 6 foot and rode a medium with Reverb at quite a height.
Posted : 19/10/2013 9:08 pm
What do you class as a medium - 18"?
Posted : 19/10/2013 9:16 pm
I would yep. Think they do a 17 as the 2014 medium but the Top tube length is only 2mm shorter than the 2013 18 inch medium, if that makes sense.
Posted : 19/10/2013 9:23 pm
If it's a 2013 or earlier model, 17 or 18 will be spot on. I'm 5 11 and owned both sizes.
Posted : 19/10/2013 9:25 pm
I have a 18 2013 model with reverb and fits perfect.
Around same height with a 29.5 inch inside leg.
Posted : 19/10/2013 9:27 pm
Great guys. Thanks.
It's a 2012 AM
Posted : 19/10/2013 9:34 pm
im a gnats chuff shy of 5'10" and ride a 17" its spot on, I wouldn't want it any smaller or larger as its ok for longer rides and pretty ok for chucking it about.
Posted : 19/10/2013 9:37 pm
+1 on the 17", I'm a nats knacker shy of 5'10" and ride a 17" with 50mm stem, I like a smaller bike so the stand over is great but has enough length for longer rides, with lots of climbing a longer stem would work great but I'm too much into downs, drops and jumps to worry about that.
Posted : 19/10/2013 9:48 pm
The top tube for the 17" was the same as the 18", just with more stand over.
Posted : 19/10/2013 10:17 pm
^^ just to add, I pretty sure everything was the same apart from the stand over height.
What size is it ?
Link here to the archive if you want further info to compare default spec etc... (ie thats its not a S or Pro with longer forks... ) however take it with a pinch of salt as spec can change per each build.
Posted : 19/10/2013 11:16 pm
18"
I'm between 5'10 and 5'11 so should be OK
Posted : 19/10/2013 11:18 pm
5'10 and ride a 16". When things get interesting feels spot on but the the seat post sticks out a lot and think if I got another would go medium. Short rides no problem, longer rides would want more room.
Posted : 20/10/2013 6:53 am
im 6.2 and ride an 18inch with a 125mm reverb feels perfect
Posted : 20/10/2013 7:54 am
Did you get it ?
Posted : 26/10/2013 1:10 pm
