Orange Five Chains...
[Closed] Orange Five Chainset
[#700706]
I have the stock raceface chainset on my 09 Pro,Thinking about getting rid of the 44t outer ring for a 38 or 40,
Will just any outer ring fit or will it have to be a raceface jobbie
Andy
Posted : 11/07/2009 9:33 pm
Doesn't have to be a Race Face specific one. I think those chainsets have a 104 BCD so a Shimano or Truvativ would fit as would a Middleburn one.
Go with a Middleburn if i were you. Running a slickshift/hardcoat 36 tooth on my Orange 5.
Posted : 11/07/2009 10:16 pm
 jonk
I thought the 5 had to have a 32 middle because of the pivot? Nick any problems with your 36?
Posted : 11/07/2009 10:24 pm
jonk - To run a 36tooth middle ring you need to fit 1 standard shimano spacer behind the BB cup or else the chain will hit the bearing cover and swingarm pivot when you drop to the granny ring.
I found that out the hard way but the frame was second-hand so i didn't mind.
As it turns out, i find that a 5 pedals horribly in the granny ring anyway! The suspension becomes waaaay to active.
I going to ditch the granny ring on my new 5 and just run the outer and middle. Using the outer/middle is actually way more efficent IMO.
Posted : 12/07/2009 9:25 am
I would never get round my weekend ride if i got rid of my granny cog !!,,,as for getting shut of the 44t outer i only ever use it if i find myself on the road while out in the peaks..and i bashed a few teeth of it the other week so a little more ground clearance would be nice
Posted : 12/07/2009 11:39 am
