Orange 5 owners?
[Closed] Orange 5 owners?
[#1592558]
I'm currently looking into replacing my frame with a Orange 5 (my current frame is a I-Drive 5).
My main concern is that on the Orange website it states:
The new rear swingarm has been designed around a standard compact drive crankset i.e. 22/32/44 with a limit of a 32 tooth middle chainring, if you use a ring larger than this then it is possible it may touch the swingarm or catch as you downshift to the granny ring.
source: http://www.orangebikes.co.uk/technical/fivebb.php
I, however have a 2x9 setup (22,36).
Can anyone clarify this? Would I just need to shove an extra spacer on the drive side? or is this a bit of a non-issue?
Posted : 10/05/2010 2:58 pm
Its the 32 which is important as the swimarm will foul on anything much bigger than a 32 which is inline with the base of th swingarm - So Yes it could be a problem IMHO 🙂
However if the 36 is far enough out from the swingarm i.e. a spacer (meaning changing the chain line) then it might work 🙂
Posted : 10/05/2010 3:06 pm
I understood it's more to do with the pivot placement in reference to the ideal middle ring. In this case 32.
It's always a compromise with having more than one chainring. So there you go. I've never noticed the chainring being that close.
Posted : 10/05/2010 3:08 pm
Ask Orange?
Posted : 10/05/2010 3:10 pm
Alternatively go 32 front and have a narrower range on the rear cassette?
Is it a new or older Orange 5 you are buying, i am running a 2 x 9 setup (with 36 chain ring) on an 08 Orange 5 without any issues.
Posted : 10/05/2010 3:12 pm
To be honest I hardly use the granny ring anymore. However I like the option :).
So essentially its a case of I need to replace my double with a triple when I can?
I wouldnt be able to get away with adding a spacer to move it out a bit? Im assuming that would make a mess of the chainline then?
Its a 2010.
Ask Orange?
I shall thank you.
Posted : 10/05/2010 3:13 pm
Not a new swingarm, but am running 22/36/bash on an 04 Five with no issues or attention paid to setup. You clearly need to speak to Orange though...
Posted : 10/05/2010 3:14 pm
One spacer behind the drive side cup is all that is required.
Anything bigger than a 32 chainring without said spacer results in the chain catching the bearing cover cap and the swingarm when changing down.
That was my experience from a 2007 5 at least.
Posted : 10/05/2010 3:39 pm
I'm running a 34 tooth middle chain ring on a 2010 five frame.
No probs here.
Posted : 10/05/2010 3:46 pm
@ davcow :
Posted : 10/05/2010 3:51 pm
This is pretty much chat Orange told me. However it will mess the chainline up slightly.
Anyone want to swap a SLX double for a triple? 😛
Posted : 10/05/2010 4:08 pm
Yeh I was right - spacer (change chainline) or change ring and rear cassette 😉
Posted : 10/05/2010 4:12 pm
I'm running a 36t middle ring on my 2010 five along with an e-13 drs, all works nicely. The front mech is close to the swingarm but not too close.
Hugh
Posted : 10/05/2010 4:18 pm
How is the DRS mounted?, if I may ask?
Posted : 10/05/2010 4:22 pm
Could do, is its a case of you sending me your bash and middle ring and me returning the rings?
Posted : 10/05/2010 4:51 pm
Could do. Though the comment was a little tongue in cheek to be honest.
I do need another crankset for another bike so thats my easiest option (ie buy a triple).
Thanks for the offer btw.
Posted : 10/05/2010 5:08 pm
@ simonb512
It's the bb mount type, it replaces a spacer on the external bb so basically the bb cup creates a friction fit....very secure and easy to set up really!
Posted : 10/05/2010 7:33 pm
Thats what I was getting at. If its BB mounted that it would more or less also space the BB.
Posted : 11/05/2010 8:32 am
Yep I'm running a 2x9 setup (22,34) no probs with the front mech at all.
Rear cassette (11-34).
Posted : 11/05/2010 1:43 pm
