Opinions on seatpos...
[Closed] Opinions on seatpost shims
[#8475897]
I won't go into the detail but (and it really isn't my fault) I've ended up with a 30.9mm Reverb and have a 31.6mm frame
Fault is with seller and I got it for a very good price. All seems well with the Reverb - other than the size
What's the general consensus on using a shim?
Posted : 29/04/2017 7:37 pm
Crack on - just make sure it's a long one (usually long enough to reach below the top tube junction)
Posted : 29/04/2017 7:40 pm
Shimmed reverbs on several bikes (inc 34.9mm) no problems, maybe use some grip paste.
Posted : 29/04/2017 7:44 pm
 cp
As above, shimmed my 30.9 reverb into 31.6 larking about bike. I purposely got 30.9 so cross compatible with my anthem. No problems at all.
Fwiw I used a USE shim. The shim really need to be long enough to reach past the top tube interface, or at least to a brace interface if you have dropped TT with corner brace.
Posted : 29/04/2017 7:50 pm
Thanks guys, shim it is. Was looking at the USE ones as it goes.
Posted : 29/04/2017 7:56 pm
