Open BB Woes - anyo...
[Closed] Open BB Woes - anyone with an Open in?
[#7484342]
(before anyone asks, I've contacted Open already, just looking for a quicker answer)
i ordered a Rotor GXP cup set, there wasn't enough axle on the NDS to fit when pressed in
was this one
so i contacted open, told them i was switching to Shimano cranks and could i order a BB direct, so i was getting the right thing,
they send this, its exactly the same as the GXP version apart from the NDS bearing is not sleeved, i tried to fit it, but encountered the same issue
http://www.mantel.com/uk/rotor-4624-mtb?gclid=Cj0KEQiAvuWyBRDO_Yzhpv_4nvEBEiQANBdXMuSmhCp_xJKKgl98eqzGoRVyq--4twFNvBfzHhGIO3gaAre38P8HAQ
i assume i actually need this? help, bb issue has delayed my build about a month waiting for various shipments from USA/Germany
http://www.mantel.com/uk/rotor-cervelo-bb-right?r=L3VrL3ByZXNzLWZpdC0zMCZicmFuZFtdPTE3NiNzdGFydDE=
Posted : 28/11/2015 3:48 pm
Yep.Open (not the latest ones) use BB right (or BB right pain in the 'arris) which is wider on the nds.
Posted : 28/11/2015 3:54 pm
If it's BBright then yes. Wheels Mfg do a better one that threads together to form a solid unit with perfect bearing alignment.
http://wheelsmfg.com/bottom-brackets/bbright/bbright-out-bottom-brackets.html
Posted : 28/11/2015 3:56 pm
yer i know its bbright, its 84mm though, so wider than standard, not sure why they would send me what they have sent me 🙁
Posted : 28/11/2015 4:20 pm
Aye - should be wider than the road version to work with MTB chainsets. Similar to 86/91mm wide shimano pressfit BBs - MTB 5mm wider than road.
Posted : 28/11/2015 4:24 pm
Ahh the mtb one is 5mm wider,did'nt know that.Yes the 2nd is correct then.
Posted : 28/11/2015 4:29 pm
Swift reply from Open, they sent the wrong one
Posted : 28/11/2015 5:53 pm
