Oneup Components 16...
[Closed] Oneup Components 16t Problem.
[#6156937]
Anyone else having problems with the 16t cog that comes with the 40/42t oneup?
New chain/ring/cassette. works perfect in every gear but the 16.
Changes up and down into it fine but skips over the top of the teeth when a crank really hard on it.
Posted : 01/05/2014 10:11 am
I had an issue when I installed mine, was a bit slow to shift... Re-read the OneUp set up guide and didn't realise it went on a certain way guided by printings on the 16t itself. Reinstalled it after reading this and been good since.
Posted : 01/05/2014 10:35 am
 scud
I just purchased an actual shimano one from Rose Bikes UK, seems to work fine and cost about £3.
Posted : 01/05/2014 1:29 pm
I've had a similar problem when I've installed a loose sprocket for a casette in slightly the wrong orientation.
Take the cassette off, make sure the 16t cog is installed the right way.
Posted : 01/05/2014 1:48 pm
Is your chain worn? Might not be an issue on the giant sprocket, but on a smaller one it could
Posted : 01/05/2014 1:59 pm
I just did what scud did and bought one from Rose Bikes - when were OneUp giving them away, I didn't get one 😥
Posted : 01/05/2014 3:10 pm
OneUp include one now, if you didn't get one then they'll sell you one for a few quid but I decided to spend a couple of quid more and get a proper Shimano one. (it was mostly postage, because obviously Rose had to send it in a box the size of a fridge)
Posted : 01/05/2014 3:20 pm
Fitted the correct way according to the instructions.
Though when you look at the steps on it they don't line up with the steps on the rest of the cassette.
I should have a shimano one from Rose waiting for me whe i return home so i'll just fit that and throw the oneup in the bin.
Posted : 01/05/2014 3:43 pm
Fitted the shimano 16t and made no other adjustments and everything is working fine now.
The tooth profile on the Oneup looks totally different to shimano.
Posted : 02/05/2014 10:08 pm
