Anyone done one?
I am trying to fit a rad-r cage to a zee mech, I am stuck here:
I can't undo the bolt that releases the clutch spring, it looks effortless in the video, but mine does not budge...
I fitted the RADr cage to Slx med cage today, no problems with the clutch bold here. Was easier than expected.
Was the bolt that holds the spring/arm in very tight? In the video it looks very easy to undo, but mine has a lot of resistance.
A bit tighter than the jockey wheel ones. Maybe yours is stuck somehow, have no other explanation.
Just fitted one to my zee mech and the bolt that you are having trouble with was very tight on mine I needed to use a lot more force than when I did my Saint mech.
ok, thanks Flee4. One up are saying it is a problem they have seen before and I should warranty replace the mech.
ok, managed to get it out, it just needs a lot of force.
