one on 456 chain ri...
[Closed] one on 456 chain ring question
 goot
[#1990150]
456 question for the masses
Want to run my 456 as a 1 x 9,
Using a standard shimano 3 ring crank, would I have clearance for a 38t on the front (middle position) ? might be a tight, but looks like room.
Thanks
S
Posted : 14/09/2010 1:54 pm
....not tried it but I suspect not
I could'nt fit a 40t bash on the outer position, so 38t ring on the middle sounds dubious.
Posted : 14/09/2010 2:05 pm
I've got a 36t middle and 40t bash with no problems, huge clearance IIRC?
IIRC early ones had tighter clearance, some were modified with a hammer as well..............
Posted : 14/09/2010 2:11 pm
 goot
thanks
so a 38t and 40t bash.. does the chain ever hop off or do you use a c/device ?
Thanks
S
Posted : 14/09/2010 3:15 pm
