One last Hope pro 2...
[Closed] One last Hope pro 2 question!
[#2324887]
Just rebuilding/rebuilt my pro2 hub and have a question about the non drive side seal and spacer.
I followed the video on the hope website on how to rebuild a pro 2 rear hub but not sure if what I have done is completely correct.
When I put the non-drive side spacer on right at the end, it doesnt seem to fit on very securely and can just be pulled off using ones hand (compared to having to use a vice when stripping it down). You can also see the edge of the green non-drive side seal when the spacer is pushed on as far as possible.
Is this right or have I done something wrong/missed something?
Martyn
Posted : 30/12/2010 8:02 pm
is the little rubber o-ring still in situ inside the nds spacer ? r.e green lip seal.. it shouldnt be toching the nds spacer as you look at it side on, there should be a tiny gap
hope this helps
Posted : 30/12/2010 11:22 pm
