one inch disc fork?
[Closed] one inch disc fork?
 mlke
[#2273654]
I've an old steel tandem with a 1 inch headset. It has cantis on it but I want to do some touring on it and if possible would like to stick a big disc on the front.
Is it technically possible? I guess I'd need a v stiff one inch diameter steel fork with disc mounts?
Posted : 10/12/2010 9:58 pm
[url= http://www.merlincycles.co.uk/Bike+Shop/Frame++Forks/Forks++Shocks/Marzocchi+Suspension+Forks/Marzocchi++MX+Pro+Lo+1+-+2010_2189.htm ]Marzocchi MX 80mm 1 inch"?[/url], or are you after a rigid fork?
Posted : 10/12/2010 10:00 pm
 juan
marzocchi will supply 1" steerer for most of its XC range. Then anygood workshop with a milling machine will make you a reducer
Posted : 10/12/2010 10:03 pm
