On One Tyres - Tube...
[Closed] On One Tyres - Tubeless?
[#6009757]
Are On One tyres okay for running tubeless? Can't seem to find anything in their product descriptions.
I have a smorgasbord on the rear, and I would be looking to put a chunky monkey on the front. I have Shimano XT tubeless ready rims, but I've never gotten round to running a tubeless set up. Does this sound doable?
Posted : 04/03/2014 5:42 pm
 sv
I run a Chunky Monkey tubeless on a stans flow rim.
Posted : 04/03/2014 5:45 pm
I've ran both on stans flow rims without any problems.
I run Smorgasboard tyres tubeless on Shimano rims without any problem. Bit tricky to seat at first but leaving them with tubes in for a day or so and plenty of soapy water did the trick.
Posted : 04/03/2014 5:46 pm
Nice one. I guess I have no excuses now then. Better pick up some valves and some tyre gunk. Any recommendations on best stuff / cheapest stuff / best deals?
Posted : 04/03/2014 5:51 pm
I'm in the process of trying to get my smorg and chunky monkey set up tubeless with stans rims and fluid will let you know how I get on...
Posted : 04/03/2014 5:56 pm
Smorgasbord on my ArchEX are absolutely fine. Some of the easiest tyres to inflate I've had yet, and they've flawless everyday since (now 1000km old).
Posted : 04/03/2014 6:07 pm
 nuke
Pretty decent sidewalls on the CM and SB tyres (should be given the weight) so found them good tubeless tyres
Posted : 04/03/2014 6:11 pm
Yes, used smorgasbords in 26 and 29, and CM in 26". Both perfect tubeless in the Alps
Posted : 04/03/2014 6:13 pm
Yup, they work. I ripped the sidewalls out of two in a row and never tried them again but it could well have been coincidence. Those were smorgasbords. I found them easy to inflate.
Posted : 04/03/2014 7:40 pm
My Chunky Monkey is ace tubeless, handles my sloppy technique in the rocky Peaks.
Posted : 04/03/2014 7:42 pm
 br
I run a Chunky Monkey tubeless on a stans crest rim.
Posted : 04/03/2014 8:01 pm
 sv
Superstar do the valves and stans fluid at CRC/LBS.
Posted : 04/03/2014 8:20 pm
Same as plenty of other up there ^^^^^^^
I've been running a 2.3 CM tubeless on the front (Flow Ex rim) for the last 9 mths and it's great at everything except sloppy mud.
No problems getting it up (Oo err), loads of grip , predictable cornering, decent amount of cushion/volume and still got plenty of tread on it
Posted : 04/03/2014 8:34 pm
As others above, no problems using Chunky Monkey's or Smorgasbords or Flows and Flow EX's. Chunky Monkey seemed a bit baggy when first mounted to EX's not sure if that was the tyre or rim, but still went up ok with track pump (pumping like a mad man!).
Great tyres and not expensive.
Posted : 04/03/2014 10:37 pm
The new 650b Smorgasbords will be tubeless ready. Also have slightly shallower tread depth for lighter weight and faster rolling, but with a more pronounced shoulder block for better cornering support.
Molds in progress. Will probably take six months to land though.
Posted : 04/03/2014 10:46 pm
Well, last night was shakedown flight for the new build, with a smorg on the back and a chunkey monkey on the front.
Tubeless on flows. Bike is a 456ti
Findings:
The chunky is brilliant! Massive, not much clearance within a 'zocchi 44ti fork with a mucky-nutz in there. Went up easily enough with garden-sprayer as a compressor.
The smorg also went up easily enough but didn't survive long in use.
Felt the rim a couple of times when riding up short flights of steps. (Which surprised me at >30psi)
On the second run down a rubbly-bouldery descent (Rivi ICR) I managed to destroy the thing. Two cuts in the tread beyond the healing capacity of Stans. Back to dual ply minion on the back I think 🙁
Posted : 11/03/2014 5:53 pm
