On One Scandel- whi...
[Closed] On One Scandel- which ridged forks
[#12138237]
I'm looks for a set of ridged forks for my On One scandel 29" frame.
I've never ran a bike with ridged forks so Have no idea whats good or not.
I know I need boost and tapered steerer but other than that I've no idea.
Anyone fitted any ( got fed up of searching thought the 29 pages of the Scandel thread) to there scandel?
Links would be ace.
cheers
Posted : 04/12/2021 12:03 pm
You want some rigid forks….
Depends on budget. Whisky Mtn forks, Enve mtn forks are lush. Carbon ones on Whippet builds are good if you can find a set.
Posted : 04/12/2021 12:40 pm
I got some carbon Salsa Firestarter ones to put on hardtail.
Nicely made, have the mounts for cargo cages. Very low weight.
Got them for about £125 second hand
Posted : 04/12/2021 12:44 pm
The selcof fork that came with frame bundle suits them. Here’s mine rigid.
Posted : 04/12/2021 1:44 pm
OP you don’t need tapered you could run straight steerer with a different headset
Posted : 04/12/2021 4:45 pm
I'm running some carbon forks from a genesis tarn. They come up on ebay for around £100. Works OK for me.
The frame takes a tapered fork but as above, you can run a tapered or straight steerer with the correct headset but yours probably has a headset for a tapered fork.
Posted : 05/12/2021 1:00 am
Tarn forks here too. They also did a steel tarn fork on the lower spec bikes.
Tarn forks are a good length and seem to be well made.
I think you'll have more chance finding a boost fork with a tapered steerer anyway, I wouldn't get anything other than tapered for it for simplicity.
Personally I'd ask on the onone Facebook group to see if anyone has a pair of selcof forks from their whippet for sale, not uncommon for people to swap them out for bounce.
There was a pair on here for sale a couple of months ago ...so you never know, this thread might remind someone!
Posted : 05/12/2021 6:45 am
What's the AC length of the rigid forks you're running with your Scandals, and do you have any comments on whether it's right/enough given the frame is designed for 130-140mm suspension forks?
Posted : 05/12/2021 9:21 am
The tarn fork also takes a 3 inch 29er tyre. I think the Selcof one does too. If you can find a fork with bolts on the side for back packing even better.
I’ve just gone the other way. I had a set of Niner carbon forks on my Scandal set up as a singlespeed but they were 100mm suspension corrected which made the front too low. I’ve recently put on some RS Gold 130 mm forks and it’s become a completely different bike.
Posted : 05/12/2021 10:18 am
I’ve got a Salsa Krampus fork on my Big Dog.
480 something a-c, needed an adapter crown race thing to make it fit in the head set and it works well.
Need to cut the steerer at some point…
Posted : 05/12/2021 11:23 am
I have a pair of the Selcof Carbon forks fitted to the Whippet if interested - not used much - decided to stick with suspension on a bikepacking bike
Posted : 05/12/2021 7:31 pm
 rone
You can get a lower bearing cup to add to the a2c length.
I've got a rigid Enve MTN fork on a frame designed for 120mm, and that's what I've had done.
Posted : 05/12/2021 8:32 pm
I have the Selcof ones on my Whippet and they are decent enough. Seem quite long and have plenty of room for larger tyres.
Could be interested in a PX for some suss forks in the near future as fancy trying it as a HT but not in any rush.
Posted : 06/12/2021 10:42 am
Oh yeah, it was the Salsa Cuthroat carbon forks I put on my bike.
Out for a ride on them yesterday, they seem good - not too harsh...
Posted : 06/12/2021 12:12 pm
