On One Scandal sizi...
[Closed] On One Scandal sizing
[#5666895]
I'm looking at getting a Scandal frame, normally I take a 19.5" frame, but none in stock at On One so looking at the geometry I'm judging whether a 21" frame will be ok.
Much of my riding is XC so I don't need a "flickable" frame as such.
Anyone run a 21" frame? How do they size up.
I'm 6' and 32" inside leg so just on the edge of the On One sizing guide.
Any help would be much appreciated.
Posted : 05/11/2013 11:17 pm
21in too big for a six footer.
18in would be perfect.
Posted : 05/11/2013 11:19 pm
I have a 19.5, i'm 6 foot with a 33" inside leg.
it's plenty long enough for me, currently running it with an 80mm stem, for XC riding and a bit of racing.
You may be able to get away with it- run a short stem, and they are quite long and low, so there should still be some standover..? Big wheels and a slightly big frame might add up to a proper gate though...!
Posted : 05/11/2013 11:22 pm
 cp
I'm 6ft and 34 inside leg. Ride an 18inch with 90mm stem and wide 3deg flat bar. Plenty big enough, and I use it mainly for racing.
21 will feel like a gate.
Posted : 05/11/2013 11:23 pm
FWIW every time Brant's recommended me a frame size it's turned out to be too small... (small Scandal and Mmmbop) and I've ended up replacing it with one size up. Just an observation 😉
Personally I'd say if you can't get the size you actually want, don't compromise... But ymmv.
Posted : 05/11/2013 11:24 pm
You've no stock of that size though Brant!
Are there going to be any more deliveries of Scandal frames or is that it?
Posted : 05/11/2013 11:25 pm
I'd be running a 50/60mm stem and 740 bars. I can only estimate stand over at approx 820mm which doesn't leave any room!!
Posted : 05/11/2013 11:29 pm
Should have mentioned I'm looking at a 29er frame.
Posted : 05/11/2013 11:31 pm
18 inch Scandal here 33 inch leg 5 ft 10. Fits perfectly.
Posted : 05/11/2013 11:32 pm
 cp
I'm 18inch on both 26er and 29er. I also have a 20inch 26er inbred, and that is gate like!
Posted : 05/11/2013 11:35 pm
29er here at 19.5in. I.m 6ft 1/2 " 34 leg, could have gone 18 I think. I've ridden Thrustys 18" 26er and it felt fine.
Posted : 05/11/2013 11:44 pm
I am 6'2 and prefer small frames but my 19.5 scandal was the best fitting bike I have had. However, I was not using it for a throw around beast and was set up for long distance xc / bikepacking. loved it!
Posted : 05/11/2013 11:45 pm
I'm similar dimensions to the OP and always feel between sizes on the scandal / whippet geometry - owned both and feel like I need a 110mm stem on them. Saying that, the med is definitely closer to being right for me than a large, I reckon. Think the 21 would not be a good choice.
Posted : 05/11/2013 11:56 pm
Robbie, you did look a bit big on it though, like it was BMX and you are more 'lanky' and 'gangly' than me. I felt your 29 er was a bit big for me framewise.
Posted : 06/11/2013 12:02 am
6ft 3 here and 19.5 frame is perfect.
If you in W Yorks you can try mine for size.
Came from a 21 inch 456.
Posted : 06/11/2013 12:04 am
6'1.5", 33" inside leg here and on an 18" Scandal 29er. Tried a 19.5" lurcher (I think) and I knew where the cross bar was! Was previously on a 20" Handsome Dog 26er that somebody else took a fancy to.
Posted : 06/11/2013 12:18 am
I have an 18" 26er, it's running a 100mm stem and its a good size. I'm 5'11 with 29" legs, usually i prefer bigger frames. I've got a lot of seatpost showing and If I was much taller I'd want the 19.5. I'd say I was on the limit of the 18"
Posted : 06/11/2013 7:21 am
 DrP
I'm 5'10" and ride an 18" 29er..
I suppose I could have done with the next size up - I've got plenty of seat post on show!
I think if I were 6 foot, I'd certainly find the frame too small - have I just got freakishly long legs perhaps?!
DrP
Posted : 06/11/2013 12:05 pm
 Yak
DrP - looks fine!
I ride an 18" too and i'm 5'8" with 31.5" legs. Fits fine with a 90mm stem. Had 16" in the past but always felt cramped or ended up with 100mm or longer stems. So would have thought 6 footers would be on something bigger than an 18"?
Posted : 06/11/2013 12:24 pm
Its funny how the guys under 6ft dont like the 18" Scandal
I'm just shy of 6'1 with a 33 inch inside leg and ride an 18" Scandal with flat, wide bars (Sunline V1, uncut) and a 60mm stem.
I don't race, but I do get to pretend that I drive a bus in the woods 😆 Which suits me fine.
Edit: My previous bike, a 26er, was a gate. Boy was I missing out on all the fun.
Posted : 06/11/2013 12:27 pm
Any official word on whether the Scandal is discontinued or not?
Posted : 06/11/2013 2:15 pm
6'1" & a 19.5 Scandal fits me just right,21 would be to big for you imo but you may get away with an 18" one....That's if you can get one,think I had one of the last 19.5's two weeks ago...
PS It's a great frame 🙂
Posted : 06/11/2013 3:05 pm
 DrP
Don't get me wrong - the current set up fits great and feels fine.
I've just been ribbed a few times for having lots of my Thomson (fnar fnar) on show!
DrP
Posted : 06/11/2013 3:23 pm
