On One Inbred
[Closed] On One Inbred
[#2721927]
I have one of the above with the sliding dropout.
Where can I get a gear cable and finishing kit with the correct ferules etc to fit the frame? At the moment its looking a bit untidy!
I cant see a kit for this on the On One website although I may be "looking like a man" as Mrs Surfer would say!
Cheers muchly!
Posted : 05/05/2011 8:45 pm
 CHB
erm...I have same frame. it is continuous cable run to rear. Any standard fittings are ok at the ends. I have a reel of shimano outer cable so length was not a problem. if you buy a "kit" then often they come with precut sections.
Posted : 05/05/2011 8:49 pm
Thanks for that.
I have done the same but the ferrules (?) I have used to fit into the small braze ons under the top tube dont seem to fit properly. In my idiocy I had assumed there must be a specific size/type. If its standard I just need to look harder.
Posted : 05/05/2011 8:54 pm
No need to fit ferrules under the top tube, the gear cable outer just passes straight through them. They are a sloppy fit though.
Posted : 05/05/2011 8:58 pm
 CHB
as above, no ferrules on top tube. full, uncut outer cable passes through.
Posted : 05/05/2011 9:05 pm
Thanks for that!
Surfer
Posted : 05/05/2011 10:15 pm
