On One Doofer
[Closed] On One Doofer
 CTML
[#1470838]
Got it in the post today to SS my 456. Not really familar with chain tensioners and it didn't come with instructions. While i was installing it, I managed to snap off one of the prongs attached to the washer, bit fragile i thought but nonetheless I continued to fit it. After the first ride i felt it didn't tension the chain tight enough (compared to a derailleur) and began to click every now and then (not slipping) so I was wondering 1.Did i snap off a vital component, like a part of a spring? 2.how can i tighten the tension further and 3.what was the clicking/noise?
Posted : 01/04/2010 9:47 pm
That pin stops the washer turning / tensions the spring against the drop out. With out it the spring is not doing its job as the spring has a similar pin which locates in the back of the washer or the spring is loaded by the shaft turning against the pin stopping it turning on the drop out. Oh I know what I mean. Drill a hole in the washer where the pin was and put a small masonry nail in the hole and then trim it down. Hey presto. New pin. In theory. 😉
Posted : 01/04/2010 9:55 pm
if u can get it working, it's a great bit of reliable kit. it works and you forget about it. Perfect for a cheapo ss bike conversion. Much better that surly singulator.
Posted : 01/04/2010 10:05 pm
 CTML
So does that mean its facked already? well thats a tenner gone down the drain...thanks on-one
Posted : 02/04/2010 12:34 am
 tron
I can see from that picture that the pin is vital to the function of the device. It does exactly the same thing as the pin on a V-brake does.
If you've actually got the thing in your hands and can't work out whether the pin's needed or not, you probably should give up doing mechanical things...
Posted : 02/04/2010 7:06 am
Teh clicking sound is probably from not having the tensioner lined up with the sprocket properly.
Posted : 02/04/2010 7:27 am
