Actually no I can't.
Yes I'm bored been on nights so wide awake.
Doesn't look very dissimilar to a canyon torque 170, just with a a shorter stroke shock. One of the only 29ers I want too.
That's the newer mega, I'm talking about the original one.
Yep.
Edit: this link http://twitpic.com/c23z5h shows the rear triangle arrangement, the bottom bracket arrangement, and the pivot placement. They are 'cut and paste' from the original mega, or I'm a Dutchman.
Edit 2: look here http://www.sicklines.com/gallery/showphoto.php/photo/16202/size/big
Nope still don't see it.
Maybe I should go and learn Flemish.........
normal threaded BB 😀
Ja.
"don't understand bike in picture.. Guapo29 isn't even out yet, isn't this pretty similar?"
apart from this is a single pivot?
ah thought it was a faux-bar, which didn't make sense either as Horst patent has expired (?)
so.. what's it for? shape and coil suggests DH but single pivots were never that great DH 'cos of braking effects i thought? and a Revelation 32mm. hmm.
just realised the EG29 is a 140mm bike, so this is a beefier AM 29er and they couldn't find a suitable fork for it yet?
Looks nice, shame about the big wheels.
Like that
Steep seat angle? Yup. Helps to winch and plummet.
Singlepivot? Yup.
Braking effects? Sam Hill seems to be loving his Nukeproof, which evolved from the Scalp which I helped scribble down. Actually this bike has the same downtube as the Scalp. A bit over built but it'll let us get the centres signed off.
Travel is 128mm, 440mm chainstays.
If they throw in a free beard with every order they´ll have a winner.
There's always a free beard - just order the bike then avoiding shaving until it's delivered 😉
Are the brake mounts straight and can you fit a front mech on?
Anyway looks good, I'm liking the departure from XC 29ers towards fun bikes to ride.
You can't fit a front mech on. No.
is there any news on an [i]affordable[/i] version of xx1? I like being able to ride up hills
Brant how would you describe what this bike is for? First 29er I've liked the look of.
Mega 29 esque?
Will they need a file?
Helps to [u]winch[/u] and plummet
It's what I'd call a trail bike. I'm well aware it's lack of front mech will cause issues but:-
1) 28/36 low gear is pretty low.
2) I don't mind walking sometimes.
3) Removing front mech capabilities lets us do other things better.
4) Life is one long compromise.
5) Other bikes are available.
Whens the updated Titus FTM being realeased?
Ta. Lack of front mech not necessarily a problem. What's a likely build weight without spending silly money? I would definitely prefer beefier forks - not sure what's available for 29ers though.
Ed's is 32lb right now, and I've got a plan to get a pound out of the frame.
Let the rushers rush, pushing the bike now and again calms the soul.
Are there any 28t chainsets available for mear mortals who can't justify XX1?
MRP blingring on a SRAM XO crank works a treat on 29er, although I should say my 29er weighs sub-26lbs. At 32lbs I'm not sure I'd feel the same way on climbs!
Brant just incase you look into this thread again-any idea on timescales for this? A long way off production?
"1) 28/36 low gear is pretty low."
24/36 (or 22/34) on a 26" wheel bike over 28/36* on a 29"er is around 2 gears lower?
*or the less costly 32/36 on a 29"er around another gear again?
Fair enough its a compromise to allow some other things, but what other 'trail' bikes are single ring only?
Kind of annoying the stays on this 29"er are the same length as my 26" EG .. it does climb pretty well tbf
Brant's on a trip for a bit I think.
