On one 456...7? - t...
[Closed] On one 456...7? - thinking about 170mm forks
[#6671815]
Black Friday bargains have got me thinking; will 170mm RC solo air lyriks on a 456 evo2 cause death/destruction?
Currently running 120mm recons (in need of a good service).
Posted : 29/11/2014 10:00 pm
At minimum trying to climb uphill will be done unicycle style......I am using 150mm Bombers and it makes it very light but I haven't snapped the head tube off....yet 😆
Posted : 29/11/2014 10:06 pm
I'm fairly sure Ed Oxley ran 160 Lyrics in the chop video.
Posted : 29/11/2014 10:11 pm
I suspect it will make it into an absolute steamroller going over rough stuff in a straight line. The downside being it will corner like a steamroller too. As always, a balancing act.
Posted : 29/11/2014 10:19 pm
Can you not get some all travel spacers fitted and drop them down to 150mm?
Posted : 30/11/2014 12:05 am
I don't like mine if iwind my lyrics past 150.... It tends to just go straight ahead.
Posted : 30/11/2014 12:09 am
I ran 160 fox 34's on mine and it gets a bit, um, floppy as far as steering goes. Fun pointed down but I wouldn't want to try more
Posted : 30/11/2014 12:03 pm
I had some tall 150mm marzochis for a while, it handled fine but it seemed to be well into diminishing returns for more travel, it wasn't any faster than 130-140mm as beyond that I couldn't get the rear end to follow through and weighting the front more wasn't possible as things got rougher it was just the time you wanted to lean back.
Posted : 30/11/2014 12:12 pm
Put some 160mm van r's on a steel 456 - front end was very floaty on anything other then downhill
Posted : 30/11/2014 12:17 pm
Same here, 150mm doesn't suit the frame very well. Ive found 140mm suits me best.
Posted : 30/11/2014 12:20 pm
I had some 150mm forks on my 456 for about 3 rides.. Hated every second.. The front end having that much travel just felt ridiculous, felt like I was getting pitched over the front at every hit.. I think the LT hardtail was a good sales gimmick, bigger is better and all that, but the idea wasn't great in practise..
130mm max travel for me on a hardtail with 100 - 120mm being my personal preference..
I definitely wouldn't feel safe on anything remotely steep and technical with 170mm travel
Posted : 30/11/2014 12:50 pm
Tried 150mm on mine, ending up settling on 140mm...as others have said, pointed straight downhill it was great with long forks but normal riding became a chore.
With the forks slightly shorter it was just as good going down but could also be hustled along singletrack and could handle a decent climb too.
Posted : 30/11/2014 2:51 pm
120-140 is the sweep spot anything more is barge territory
Posted : 30/11/2014 3:09 pm
I rode mine with a 170mm Mars 55 while my 44 was being fixed. Loved it. The combo made the bike so capable feeling that I scared myself with how fast I was going into rock gardens etc. My 44 is 150mm and makes for a better all rounder but I say go for it.
Posted : 02/12/2014 12:41 pm
