On-One 456 Wheelbas...
[Closed] On-One 456 Wheelbase?
[#3666197]
The On-One site has some geometry for the 456 frames but no wheelbase measurement.
Anyone know where this can be found?
Can't really differentiate much between the sizes otherwise.
Ta.
Posted : 11/02/2012 11:36 am
 br
Long...
If its a 20" (with 140mm forks) you are after I can go and measure?
Posted : 11/02/2012 11:47 am
To be honest - I'm trying to find the difference between the 16", 18" and 20" frames with respect to wheelbase. I'm reckoning there's not much in them.
Posted : 11/02/2012 3:13 pm
 br
20' is 117cm with a 140mm Thor fork
Posted : 11/02/2012 3:18 pm
My 16 " with 100 forks is 114-115 cm [ does have a 10 addition to bottom cup] as i did not measure that accurately
so at the two extremes you get 2-3 cm or in engineering talk"not much in it"
HTH
You got lucky that the only two to measure were at opposite ends
Posted : 11/02/2012 3:53 pm
As I thought - bugger all between the 3 'main' sizes.
They're basically ALL the same size with different seat and Head Tubes.
Weird.
Posted : 11/02/2012 5:10 pm
