Old school BB quest...
[Closed] Old school BB question
[#10260264]
This probably comes into the bleedin obvious category but I just wanted to double check - I've only done HT2 BBs before.
I'm swapping all the bits from one frame to another for one of my kids. Cranks are square taper - shell on old frame is 68mm, new frame is 73 mm.
I'm struggling to get the old bb out to check the spindle width - measuring with a ruler I'm pretty sure it's 113 mm.
So I'm assuming I just need to order a 73mm 113mm spindle bb for the new frame?
And any recommendations - Shimano UN55?
Thanks
Posted : 04/10/2018 10:31 pm
I'd say you're right on both questions.
Posted : 04/10/2018 11:00 pm
There are at least 2 different square taper patterns.  Are you sure the current one is shimano ?
Posted : 04/10/2018 11:03 pm
Haha, I knew this would happen. The cranks are Truvativ - does that help ?
Posted : 04/10/2018 11:16 pm
Have you tried the " BB removal tool in a vice, lower bike frame onto tool, rotate the frame" method?
Posted : 04/10/2018 11:17 pm
 JoeG
https://www.sheldonbrown.com/bbtaper.html
Posted : 04/10/2018 11:20 pm
Thanks Squirrel, I'll try that. JoeG - no mention of Truvativ on there but I guess if I can confirm that Truvativ are JIS then shimano BB would be fine..
Posted : 04/10/2018 11:35 pm
Shimano bb will be fine with Truvativ cranks.
Bolt the bb tool onto the bb with a crank bolt and washer then put large socket , often 32mm over the bb tool and use a large bar and maybe some heat
un55 is about all you can get that’s ok now since un72 was dropped
Posted : 04/10/2018 11:50 pm
Thanks orangeboy that's the info I needed!
Posted : 05/10/2018 12:07 am
