Old drivechain woes
[Closed] Old drivechain woes
 bubs
[#7002436]
I have built up one of my favourite old frames with parts that were lying around my shed. All looks good and works surprisingly well except for the drive train which appears to lock up or jam when moving between small cogs at the back. It is not clear what is jamming. Any ideas what may be causing this? I think I have matched up the worn together chain and cassette but could a mismatch here cause more than just skipping? Back pedalling barely works too. Is it possible to incorrectly thread the chain through the rear mech?
Posted : 16/04/2015 8:43 am
it is possible to incorrectly thread the chain through the rear mech although it shouldnt cause the wheel to jam and lock up.
is the chain the correct one for the cassette i.e. you've not stuck an 8speed chain onto a 9 speed cassette as the chain is slightly wider...the other way is generally fine as the chain will be narrower.
if the chain and cassette arent the matched up ones from previous use then that could be the issue
check the rear mech is working fine too and that its indexing is accurate, then check the cable tension to ensure the mech is lifting the chain far enough for the chain to sit correctly on each sprocket
Posted : 16/04/2015 11:04 am
