Oil wights......Fox...
[Closed] Oil wights......Fox 36 service
[#5666699]
Going to do a lower leg service on my 36 Talas in the next few weeks however i find the price of fox oil appears a little steep??
Will any 7 weight suspension oil do the trick?
Also whilst im on what effects would different wieight oil have on the function of the fork??
Thanks
Rob
Posted : 05/11/2013 10:32 pm
I went to the Oil of Wight once.
Posted : 05/11/2013 10:41 pm
Not a lot its lubrication only,
Posted : 05/11/2013 10:43 pm
Tom Bombadil will save you from the Wights, he had a hot wife too
Posted : 05/11/2013 10:46 pm
Just done a Fox forks service and used 7 weight oil from a motorbike shop...
Its not very technical but all seems fine. Used fox blue on the phone rings....
Hth
Posted : 05/11/2013 11:18 pm
Shouldn't it be 10wt?
http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm
Posted : 05/11/2013 11:38 pm
Indeed, just checked the bottle, it was 10wt, thats the chart I used as well
Posted : 05/11/2013 11:52 pm
yeah i have seen the oil volumes stating 10wt but then in the service guide it states 7, im presuming it makes very little difference....think i will just grab some motorbike 7wt or 10wt once the seal kit arrives
Posted : 06/11/2013 12:01 am
Now 10wt oil. Cannot remember how much i stuck in thou.
Posted : 06/11/2013 12:18 am
I used generic motorbike 10 wt for ages. Only recently did i find that not all oils are equal. Some are better for damping some better for lubrication.
My 36's use fox red (silkolene rsf) 10wt and fox green- also 10 wt. It's definitely worth using the correct stuff- only wish I'd realised sooner.
Get it on the internet and its not too much more money
From the internet- fox green fluid is torco rsf medium.
Posted : 06/11/2013 12:26 am
For the sloshing around keeping bushings lubed type oil, I use motorcycle engine oil. It's not doing anything suspension wise but clings really well. As motorbikes generally have a wet clutch, it should have a pretty good shear strength as well.
Posted : 06/11/2013 12:32 am
ansdy - Member
You read this then?
http://www.peterverdone.com/wiki/index.php?title=Suspension_Fluid
Viscosity chart at the bottom of the page is worth a look.
Posted : 06/11/2013 1:28 am
This stuff? You're right, Tesco's own brand is cheaper. But it's slippier and you can't get your salad leaves balanced on the fork as easily.
Posted : 06/11/2013 2:12 am
Fox 10wt green is pretty much the same weight as most generic 15wt.
Posted : 06/11/2013 11:06 am
