Anyone using oil in the lowers of a pike rct3 2016/17 that is not the 0w30 rockshox fluid?. I don't have any but do have Rockoil 15wt in the garage.
It'll be fine.
I use fully synthetic 0w30 engine oil.
I use Fox Gold 20wt, forks seem to stay plusher for longer than when using 0w30.
I used whatever the lower leg lube is from the tftuned's service kit..put the same in my bluto.
Doubt I'd notice any difference between the weights.
Yep TFT lower mix or whatever they call it.
TFT lower mix they spec for various RS forks including the modern Pikes. Still got loads of it from use on other forks and planning on using it for next Pike service. Should be fine as that's what TF use even if it's not the strict RS spec.
