Changing seals on my revs and have some TFT lower lube mix left. Manual says 15wt oil but I wondered if I could use the TFT stuff as I believe it is 15wt with a little something extra in it. Going to use it the lowers too.
Posted : 17/01/2013 9:38 pm
You can use anything that the sponge can hold I would have thought
Posted : 17/01/2013 9:43 pm
Use the same fluid as is in your forks. If 15wt then 15wt, if TFT then TFT. Less of an issue with contamination though it would only be minor quantities.
Posted : 17/01/2013 10:18 pm
Yes you can use the tft lower mix for the foams, ( its far better than 15wt suspension oil).
Posted : 17/01/2013 10:20 pm
