I currently have a 63mm stroke spring on my Kenevo and want a heavier spring
The 63 is discontinued, can't find the right weight one anywhere
What effect would it have putting a 67mm spring on?
I have quite a bit of preload wound on to my current spring
Have you had a chat with Brink. Still showing some on their site
Get a different brand?
Cane Creek Valt springs should fit a TTX, I used to run the progressive version on one.
If your shock can accommodate the extra spring length the only disadvantage will be the 67mm stroke would in theroy be slightly heavier than the 63mm stroke option.
They are probably just streamlining options as 65mm is one of the the metric standard sizes
It can easily accommodate it - heavier phsical weight (not an issue), or heavier spring rate?
[url= https://live.staticflickr.com/65535/53118095608_7344249966_k.jp g" target="_blank">https://live.staticflickr.com/65535/53118095608_7344249966_k.jp g"/> [/img][/url][url= https://www.flickr.com/gp/85252658@N05/8qB5Bk9097 ]2023-08-15_08-36-01[/url] by [url= https://www.flickr.com/photos/85252658@N05/ ]davetheblade[/url], on Flickr
I'll have a looky - need a -15
*edit - they do have them, thanks 🙂 @Tracey
Heavier physical weight. At least you have a few options 😎
