You need a Hope H mount as IIRC the RXF 36 has a 180mm post mount fitting as standard.
Shimano 180 adaptor fitted to ours
Thanks for your answers.
Have any image or link about these adapters?.
I want for front disc.
CRC have both on the same picture on their site. Think we paid £5.99 for ours. It comes with two different length longer bolts to mount it.
Is this, right?: [b]180mm Rotor - PM160 Fork[/b]
Thanks!.
It is with the Ohlins as it's set up for a 180 rotor in that you wouldn't need a mount for it so you need the 180 adaptor to make it fit a 203 rotor
Perfect!.
Of the 2 adapters that CRC have, I need buy the [b]180mm Rotor - PM160 Fork[/b], right?.
Thanks.
That's the one. The bottom one in the picture. Just make sure you put the longer bolt through the wider part of the adaptor
Okey, perfect!.
Thanks again! :).
