Oh C*CK! incompatib...
[Closed] Oh C*CK! incompatible parts - again...
[#2510219]
Just got a new Cotic Sould frame and some nice shiny Hope Tech brakes. I am running AM - Pro 3 wheels with a 4 four bolt 180mm disc. No good then that teh brake comes with a 183mm 6 bolt disc. Should have thought of that one sooner. I'm sure I can sort it out, but it is bother as I'll end up with the old 180mm 4 bolt disc I can't use.
Seems impossible to do things on the cheap!
Jim
Posted : 26/02/2011 11:01 pm
ha ha well done jim, there's nowt like planning 🙂
Posted : 26/02/2011 11:06 pm
 cy
Surely a 180 and 183mm disc will work OK on the same caliper? Maybe you just need a slightly different Hope adaptor bracket for the disc mount?
Posted : 28/02/2011 11:44 am
Try the 180 - bet it will work. Sell the other.
Posted : 28/02/2011 11:50 am
Thanks for the advice, but I have a bit of an OCD for things like this. I am getting a 183 rotor now. I am sure it would work with a 180, but I think you would get some spurious pad wear.
Just means I'll have to wait a bit longer until I can get some forks sorted. Frame looks sweet though - I can now see what you pay for! Shame for it to be gathering dust whilst I sort stuff out for it.
Posted : 28/02/2011 11:05 pm
it's 1.5mm, that's about()<- that much
Posted : 28/02/2011 11:10 pm
Couldnt you just have sliced 1.5mm off each post mount on the adapter...
Posted : 28/02/2011 11:12 pm
Think i would have shamfered the pad a little,Nor sure 1.5mm is worth cahnging rotors for.
Posted : 28/02/2011 11:15 pm
