Obscured serial no
Obscured serial no
[#12549145]
I am on the verge of submitting a warranty claim for a frame and need the serial no. It is stamped on the BB shell as expected, but the paint is so thick, it has effectively obscured the numbers. All I can see are very faint indentations in the paint. I have tried the old tracing paper trick to no avail and have even tried rubbing in powdered graphite (soft pencil lead) to give the numbers some definition. I have had a result but nothing conclusive. Shining a light from an oblique angle isn't very effective either.
Any ideas how to get round this problem? It can't be the first time it has happened.
Posted : 21/09/2022 3:44 pm
Did you buy it new? Any paperwork still with it? Frame numbers can be written on the paperwork...is that any use?
Posted : 21/09/2022 3:50 pm
Bit of nitromors? Apply with a small modelling brush? Then cover the cleared area with some lacquer?
Posted : 21/09/2022 4:05 pm
Tell the company who are honouring the warranty (frame mfr I assume) that you can't read it because their paint is crap? Can't be the first time they've had the problem.
Posted : 21/09/2022 4:08 pm
Who is the serial number for? The bike shop/manufacturer?
I'd explain the problem to them & ask how they want you to proceed.
It's not really your problem to solve if the manufacturer can't make a legible serial number.
Could you take a photo of it & send that to them?
Posted : 21/09/2022 4:09 pm
I had a similar issue with both my Orange FS bikes, but found that if you shone a light on them (phone torch) from different angles they became a lot clearer.
Posted : 21/09/2022 4:12 pm
I bought the frame new but it was in 2015. Any paperwork is long gone but....it did have a lifetime warranty.
The serial no is for the manufacturer. The LBS is handling the warranty claim for me and if the details I have tried to read thus far are no good, I'll take the frame to them. It is however almost a couple of hours round trip so I'd like to avoid that if possible.
Posted : 21/09/2022 4:14 pm
Did you buy it from your (not local) LBS?
Is it not possible they have records?
Posted : 21/09/2022 4:18 pm
They have records but not the serial no. I'll have another go working out the number and get someone else to look and see if they get the same result I did. If not, it looks like I'll be getting in the car.
Posted : 21/09/2022 4:26 pm
Cracked your 'ball John? 😮
Posted : 21/09/2022 4:56 pm
Yup.....
It's all the power I put through it. :o)
Posted : 21/09/2022 5:02 pm
Can you not take pics of the obscured serial number and send them to the shop so that the manufacturer can sort out their own problem?
Posted : 21/09/2022 5:03 pm
 Olly
post a picture here so we can play "guess the serial number"?
Posted : 21/09/2022 5:40 pm
In all honesty, a few photos correctly focused (not too close and tap the area you want to focus on) and flash on/flash off are often more legible than by eye. I've used it to read old part numbers on vehicle components.
Posted : 21/09/2022 6:56 pm
We records frame number on orders and it's often quite hard work, the ones I enjoy most are where they clamp a cable guide over the top and you have to undo both gear cables to move it.
Posted : 21/09/2022 9:21 pm
