Im sure i read a thread where an enterprising aoul had sourced rubber 'o' rings to fix the leaky Shimano caliper problem.
Im afraid i cant now find it. Does anyone have the link to the 'o' rings used?
Thanks
Brilliant. Thank you
The piston kit also looks interesting....have you used it?
^^ I think I might give that a go, out of interest really. Â The write up gives me confidence 😀
<div>1. contact to make the film using high temperature insulation materials, can rely on heat 300 degrees Celsius, heat and reduce the heat attenuation;</div>
<div>2. Surface four groove air hole design, can reduce the heat transfer contact area, increase the air shuttle, which will help to heat;</div>
<div>3. The back of the depression design, the oil thrust concentrated in the central, so that the piston and the ring concentric activities;
Package included:
1Pcs piston and 1Pcs Sealed</div>
The description parallels my knowledge of rebuilding brake calipers 🙂
