Numpty tubeless que...
[Closed] Numpty tubeless question
[#6213298]
If I'm using a Stan's tubeless kit or similar with presta valves, but the rims are drilled for Schraeder valves, will this work, need some bodging, or be totally hopeless? One rim still has the grommet to hold a Presta valve if that makes any difference.
Ta.
Posted : 22/05/2014 10:31 pm
I tried all sorts, presta valves popped right through with the pressure, got Schrader to presta adaptors, couldn't screw the valve of just rattled loose, trued some Schrader valves wouldn't fit due to the rim shape.
In a word I wouldn't bother.
Posted : 22/05/2014 10:55 pm
Ta, I feared as much.
Posted : 22/05/2014 10:59 pm
Stans NoTubes Rim Strip For Freeride All Mountain & Flow Rims could be an option. They have a Schrader valve in the rimstrip. However the strip is designed for wider rims AFAIK.
Edit [url= http://www.tredz.co.uk/.No-Tubes-Stans-Freeride-Rim-Strip_53061.htm?utm_source=Google&utm_medium=AdwordsProductAds&utm_campaign=Adwords&gclid=CLHpsabEwL4CFcbKtAodDjYABg ]Clicky[/url]
Posted : 22/05/2014 11:01 pm
Stans rim strips work perfectly fine in Schrader rims, I've run one in a mavic 719 for years. If you're just taping up the rim, a quick google found these: http://www.chainreactioncycles.com/no-flats-tubeless-schrader-valve-kit/rp-prod94761
Posted : 22/05/2014 11:12 pm
