Numpty shock pressu...
[Closed] Numpty shock pressure question....
 GDRS
[#410142]
Right - It is sunny and i have put the singlespeed in the shed for sunday's ride.
Out comes full suss. Comm Meta. Its been a while. Suspension feels really soggy. Can't rememeber the base pressure settings (i.e start point for tinkering)for an 85Kg idiot with a Float 32 and an RP2.
Will tinker etc later - but any ideas on the pressures?
Posted : 21/03/2009 4:46 pm
Just pump it up until you get ~25% sag & then merrily adjust from that point
Posted : 21/03/2009 4:52 pm
 jimw
the fox manuals suggest approx 95psi for the fork, the pressure in the RP2 depends on the bikes geometry- I have an RP23 on an Orange 5 at the same weight as you and it needs 210psi, but the same shock on a Trek EX needs 'only' 160psi
Posted : 21/03/2009 5:00 pm
 IWH
For future reference I was passed a trick by an old motorcross racer which I've found really useful: Fix a square of yellow duct / gaffer tape on the shock body or fork with your base pressures & settings in permanent marker. Handy if you've got a few different suspension systems in use 🙂
Posted : 21/03/2009 5:11 pm
