Numpty road crank q...
[Closed] Numpty road crank question
[#899206]
I have a 53-39 set up on the front but there are too many hills around here!! Can I just swap the rings for smaller ones and adjust the front mech to suit? Thanks in advance.
Will
Posted : 26/09/2009 8:29 am
If that's how your chainset was supplied, then there's more than a strong probability that your chainset is either 110 or 130. Which in turn means the smallest inner you'll get is a 38T. The smallest outer would be a 46T, but you have to specify a 46T OUTER.
Have you looked at your cassette?
Posted : 26/09/2009 8:39 am
Depending on what spec your chainset is, you might find a whole new compact chainset going cheaper than rings alone.
I just bought a back up FSA Gossamer compact for cyclocross and it only cost £29. A new ring is about £26.
Posted : 26/09/2009 8:43 am
Cheers oldgit. Can I just put a full new crank on then? The one I have has had little use so could just sell that to offset the cost.
Posted : 26/09/2009 9:02 am
Yes as long as it matches your bottom bracket, what have you got?
Posted : 26/09/2009 9:06 am
If it woulds fit, I have a 36 inner ring on the classifieds.....
[url] http://www.singletrackworld.com/forum/topic/fsa-36t-ring-as-new [/url]
Posted : 26/09/2009 9:24 am
surely just change your rear cassette?
Then you have a one for the hills and one for the flats?
Forgive the heresy here but hey even fit a mtb one?
Posted : 26/09/2009 9:25 am
cassette options are going to be limited by what rear mech is on bike
Posted : 26/09/2009 9:26 am
Again without knowing what will has, it's more likely he has a rear mech limited to about 27T if he has a bike supplied with a 53/39 chainset.
Posted : 26/09/2009 9:31 am
The crankset is a Ultegra SL
Posted : 26/09/2009 9:44 am
Smallest inner ring you can fit is 38t. If you want lower gears then sell the chainset and buy a compact double or even a triple if your shifter is compatible.
Posted : 26/09/2009 9:49 am
If you have Ultegra SL you don't really want to downgrade to a cheaper Shimano compact. Assuming it uses HT11 bearings, the cheapest compact would be something like a Tiagra at about £40.
I'd probably sell and replace it with the same spec kit.
Or move 😉
Posted : 26/09/2009 9:53 am
Cheers everyone. Oldgit thanks for the help. I will get a replacement SL one. It is a HT2 BB. Anyone want to buy a 53-39 crankset??????
Posted : 26/09/2009 9:55 am
53/39 is too Grrrrr for STW.
Posted : 26/09/2009 9:57 am
HaHa. It's no good for my old unfit legs!!
Posted : 26/09/2009 11:25 am
