Numpty Q - regreasi...
[Closed] Numpty Q - regreasing bearings
[#413224]
Got some sealed bearings that are a bit gritty so i pop off the seals and inspect - clean but little grease. So using a grease gun i pump grease into the cage either side of each ball, rotate and mucky grease comes out. Wipe this away and repeat whilst spinning bearings. Trouble is i am sure i am using more grease than is worth while, am i doing it wrong?
How do you get more grease in without it coming back out?
Posted : 22/03/2009 10:18 pm
Flush the dirty grease out with degreaser first, then once it's clean and dry pack with fresh grease. Degreaser's designed for this after all.
Posted : 22/03/2009 10:35 pm
as coatsey says - but grease is cheap at a tenner a kilo and you will not get muich more life out of those bearings. It'll do until you can get new ones.
Posted : 22/03/2009 10:38 pm
Still got the question - how you get the grease in without wasting so much??
Posted : 22/03/2009 10:42 pm
smear it in with your fingers, doesn't need to be packed in solid, just work it into the gaps.
Posted : 22/03/2009 10:51 pm
if you smear it just goes onto the top of the cage no?
Posted : 22/03/2009 10:52 pm
What do you mean waste. Are you ladling it on to the floor or pushing a little bit at a time in with your finger tip. I assume these are bearings for a bike and not a tractor or oil rig.
Posted : 22/03/2009 10:54 pm
waste as in squirt with grease gun some goes in some then curls back out like a shit, this is then "waste"
Posted : 22/03/2009 11:00 pm
Jeeze !
Posted : 22/03/2009 11:17 pm
Use your bloody fingers man! grease costs pennies anyway
Posted : 22/03/2009 11:22 pm
Right Bearings out and seals off, bath in neat fenwicks for 30 mins, sluiced with boiling water, re-bathed in fenwicks, scrubbed with the nail brush (don't tell the Mrs!!), re-sluiced in boiling water, wd-40 to drive water out. Cloth dried and now on the radiator, ready to repack with quality grease!!
Is that right??
Posted : 23/03/2009 6:35 pm
I'm thinking if you've gone to the trouble of getting the bearings out you might just as well fit new ones 🙂 I'm going to be testing some Ebay specials to see how long they last compared to SKF...
Posted : 23/03/2009 6:43 pm
got some ebay cheapies on the way but it was no bother to get em out as the old swingarm was going back to 'dale for warranty so just pressed the old bearings out
Posted : 23/03/2009 6:48 pm
all reassembled - seems great
Posted : 23/03/2009 7:46 pm
