numpty Pannier ques...
[Closed] numpty Pannier question
[#6235576]
so getting ready for a night away and putting on my new panniers as I cant get my stuff into seatpack. Question is, I have enough to 2/3 fill one pannier (Ortlieb back roller plus) - is the bike going to feel unbalanced with just one one, should I split the stuff between 2 so it's weight balanced ?
Thanks
Posted : 30/05/2014 8:53 pm
You won't notice. Just check the rack bolts are nice and tight.
Posted : 30/05/2014 8:55 pm
One's OK if it doesn't weigh much. If it does, I'd use two. (from my limited experience)
Posted : 30/05/2014 8:56 pm
Just take the one, Ortliebs are heavy, no need to add weight. You'll adjust in the first mile or two, probably without noticing.
Posted : 30/05/2014 8:58 pm
Many thanks
Posted : 30/05/2014 9:02 pm
If you ride no hands a lot then go for two, if you don't go for one.
Posted : 30/05/2014 9:10 pm
 kcal
I usually use two just for balance... when I commuted, used only one and that was fine as well.
