Nukeproof Pads Vs S...
[Closed] Nukeproof Pads Vs Shimano?
[#9339171]
Hi
Has anyone got any feedback on Nukeproof pads compared to Shimano pads? For example the standard Shimano resin G01S vs Nukeproof Resin or Semi metallic pads?
Just about to change from the basic RT56 discs to RT66 and want to also refresh my pads after a contamination of the pads material.
thanks in advance.
Posted : 21/05/2017 1:22 pm
The nukeproof semi metallic pads work fine for me. The only downside is you don't get a replacement split pin with them so you'll need to reuse the bolt or split pin you've already got.
Posted : 21/05/2017 6:15 pm
ok thanks will keep the old ones when I launch the pads
Posted : 21/05/2017 7:54 pm
