My Mega frame has come with the ML tune label on the body of the shock (Medium Rebound/Low compression. Reading some reviews (yes,I know)they state that after initial tests/reviews the shock was altered to a heavier tune for support. Therefore, should I have received an MM labelled shock or have they adjusted the ML tune?
I'm not heavy at 69kg and have just added two bottomless rings which I've only tested on the road so far, which have made a difference to feel, in that it's more lively/supportive than before.
What I'm really asking is -have I got the latest shock or been sold "old stock"?
Thanks guys n gals
The new shock is M/L tune - previously it was L/L. But the other difference is that you should have a High Volume sleeve rather than a Debonair one.
Yes, I've got the high volume sleeve non Debonair, so I have the latest tune which is good news!
