Need a boost rear axle for a 2018 NS snabb frame but for the life of me I can't find what thread pitch anywhere, Dartmoor look to be 1.75 but any ideas?
That robert axle project link someone posted earlier might be useful
https://robertaxleproject.com/axle-finder-2/
NS not listed, but depending on length it's probably one of these:
https://robertaxleproject.com/shop/lightning-bolt-on-axle-rear-12-mm-x-170-mm-x-1-75-thread/
https://robertaxleproject.com/product/lightning-bolt-on-axle-rear-12-mm-x-174-mm-x-1-75-thread/
https://robertaxleproject.com/product/lightning-bolt-on-axle-rear-12mm-x-180-mm-x-1-75-thread/
I sold a 2018 NS Snabb 29er frame a while ago and zooming in on the picture I can see that the axle says on it NS bikes co 180.
Don't know if the 180 gives any indication of anything?
If you find the size I recommend the brand x axles off chainreaction for best value.
Can you measure the thread pitch in the frame itself?
Thanks, don't think I can measure the pitch accurately enough so will probably go for a 1.75 pitch brand-x. Worse case return if wrong, tried messaging NS bikes but no response as yet
180 is the length. Wolf tooth do an 'axle guide'you can print out, shoes the three different thread types.. might be able to compare to the frame
