NRS flange bushings...
[Closed] NRS flange bushings .. is there an alternative?
[#5493868]
Can anyone help?
I'm looking for a cheaper alternative than to source a Giant NRS bearings and bushing kit which is expensive.
All I need is to replace the nylon flange&bush arrangement in the seatstay/chainstay joint.
Do you think it could be replaced by a bearing?
Anyone tried anything different?
Posted : 07/09/2013 8:08 am
 StuE
I used kit from Betd for other half's NRS
http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=62&Name=Giant+Replacement+Bearing+kits
Posted : 07/09/2013 9:29 am
ouch!
they cost more than the frames worth! ... but thanks anyway
Posted : 07/09/2013 6:00 pm
 StuE
What year is it? if 2004 or later then they are cheaper from here
http://www.enduroforkseals.com/id239.html, if older I think you are stuck with Giant or Betd, on the upside the Betd kit changes the seatstay/chainstay flange/bush arrangement for bearings, which when I had to change them were a couple of £ each for SKF bearings from local bearing suppliers
Posted : 07/09/2013 8:03 pm
