[URL= http://i74.photobucket.com/albums/i264/Northwindlowlander/Capture_zpstf99bbki.jp g" target="_blank">
http://i74.photobucket.com/albums/i264/Northwindlowlander/Capture_zpstf99bbki.jp g"/> [/IMG][/URL]
Tied-up Satyr.
so much indecision!
is this an accurate representation of your ride or a complete **** up?
I had this issue on Wednesday. I was using my phone and it was in some sort of hiper powersave mode!
Kudos!
Top right hand corner is perilously close to a C&B.
jekkyl - Memberis this an accurate representation of your ride
Yes. Especially the bit when I went 46mph up a fire road.
Ignore the pentagrams though, nothing to worry about.
Mechanical? 🙂 After all that and you couldn't complete the loop!
Did a swarm of wasps periodically fly into you leading to the small squiggly bits ?
superfli - MemberMechanical? After all that and you couldn't complete the loop!
Loop! What sort of person looks at that and thinks "loop"? 😆
Ming the Merciless - MemberDid a swarm of wasps periodically fly into you leading to the small squiggly bits ?
They're about 100 metres across. The squiggly bits I mean, that'd be an uncommonly large wasp, and probably not a lot of point running from it
Etch A Sketch on acid..
How many KOMs?
My personal record is 72 kmph while out walking (Endomondo) ... max speeds and elevation data is frequently rubbish 😐
